Looking for D311 a/c generator
Showing 1 to 6 of 6 results
bequest66
Send a private message to bequest66
I have a 1947 D311 gen set 4V5892, which I bought in December. It has 2475 hours on the meter and after very little work, I got both engines running. Being a mechanic and not an electrician, I didn't pay attention to the fact the generator is 125 volts D/C output. That crushed my dreams of using it for stand-by power for my house! It is also missing the frame mounted fuel tank. Just wondering if anyone would have a generator and tank available, as the engines run great. The diesel has high water temp and low oil pressure shut-down and the starting system is 12 volt. Any info would be greatly appreciated.
Tue, Mar 13, 2018 10:08 AM
WA7OPY
Send a private message to WA7OPY
A gen will be a little hard to find, as i remember the unit is 1200 rpm??....WA7OPY
Tue, Mar 13, 2018 9:39 PM
Thank you received: 77
Reply to WA7OPY:
You could look into whether your generator could be reconfigured for 120/240 60HZ. There are folks on here (looking at you, cc) that could point you in the right direction. Your other option is to just look for a six-pole generic generator if it's 1200rpm or a 4 pole if 1800 - I read somewhere that the Chinese junk heads are ok if you first go through and "detail" them
Tue, Mar 13, 2018 10:00 PM
657cat
Send a private message to 657cat
I have a D311 I am parting out. 120/240 V 20-25KW if memory serves me correct I can check when I get home later
Wed, Mar 14, 2018 2:16 AM
bequest66
Reply to 657cat:
Thanks. If you could check on it sometime, that would be great, but it's not a big hurry. Also, I'm not sure if the base would be the same, but some measurements would solve that. My local electrician thinks mine was military, but there are no military tags on it. It apparently was equipped with a "residential" muffler, which is gone, but the brackets and flex pipe were on it yet. It also has a 12 volt system for starting the pony. I'm not very familiar with the gen sets, but I have owned graders and dozers for over 30 years. This d311 caught my eye!
Wed, Mar 14, 2018 9:27 AM
lghtspeed
Send a private message to lghtspeed
Reply to bequest66:
I also have a genset d311 id sell the generator off from. Ill get its specs later today.
Wed, Mar 14, 2018 9:37 PM
bequest66
Reply to lghtspeed:
That would be great. I live in LaMoille IL, which is close to Lasalle/Peru. Thanks
Thu, Mar 15, 2018 12:23 AM
