Looking for D2 track pads
joshua.haan
Send a private message to joshua.haan
Hello
New member here
I have a D2 5U 6096 that needs new tracks. It has the 23 1/2 idlers so it needs 31 links per side from what I've read. I have found a source for new rails but I would also like to replace the pads if I could since the old pads are very worn. I have a D2 5J 5046 parts machine that has just 29 rails & pads on each side with the small idlers. They are 12 inch wide pads. The pads on the 5J could work if they had to but obviously I'm 4 pads shorts if I do that. So I'm just trying to see if anyone has a few extra D2 track pads in decent shape to sort of complete that set. Worst case scenario, I could use a few of the bad pads off of the 5U but I really don't want to do that because they are 13.5 inches wide and very worn. Otherwise, maybe a long shot, if someone had a full set of pads (any width that works with the 2S blade is fine) that would be great too. Just to clarify I'm only after the pads and not the actual rails. Located in Northeast, Iowa. Thanks
Tue, May 14, 2024 9:53 AM
joman
Send a private message to joman
PM sent, Thanks
Tue, May 14, 2024 11:08 PM
