Looking for Cat 22 original starter and Rear PTO Pulley assembly
Scott Kuehn
Send a private message to Scott Kuehn
We're deep into a Cat 22 restoration, (2F series) and as the saying goes, "It ran when it was parked...."  Little did we know that was 70 years ago. Luckily we have several parts 22's that we've acquired.  One the engine is good, but transmission is toast, another just the opposite and so on.
The one we want to rebuild was from Westmont Tractor in Missoula, MT and they were the Cat dealer here for 50+ years.  It had the original starter, generator, and battery box.  (Original starter and ring gear, not a retrofit) The starter was missing, but the generator is there.
Anyone have or have a lead on an original Cat starter for a 2F 22?  I heard the retro fit starters won't fit the original ring gear.
Also looking for a rear pulley assembly.  (We have two PTO's, but will use only one if anyone is interested)  We have several pieces at our museum that are belt drive and a pulley on the 22 would work perfect to run them.
I'm sure we'll have lots plenty of spare parts when we're done if your in the need for something
Sun, May 12, 2024 2:15 AM
Thank you received: 77
Brewzer may have a Twenty Two belt pulley for you
Sun, May 12, 2024 6:26 AM
brewzer
I have the rear PTO pulley assembly. Located in Morgan Hill, CA. $600.
Mon, May 13, 2024 5:18 AM
Scott Kuehn
Reply to brewzer:
I'm interested. I have a PTO on two of our parts Cats, does it bolt onto that, or do you take off the PTO and replace it with the pulley assembly? I'm assuming it's big enough, would have to be shipped on a pallet.
We're also looking for an original starter for our 2F restoration.
Scott
Mon, May 13, 2024 8:34 PM
brewzer
Reply to Scott Kuehn:
Scott
The PTO you have on your tractor would be removed and the belt pulley put on.
Mon, May 13, 2024 9:45 PM
Peter C
Send a private message to Peter C
Reply to brewzer:
Scott, for shipping estimates, I weighed my 22 belt pulley at 160 pounds.
Pete
Mon, May 13, 2024 11:09 PM
