Longshot request 29.5 x 29 wheels
Willowhic
Send a private message to Willowhic
I'm in the market for two wheels/rims on which I can mount 29.5 x 29 tires that I already own. The configuration of the wheel doesn't matter; that is to say that the wheels can be from the rear of a scraper or from a 988 axle with the planetary ring gears mounted in them (even better if I could get the whole axle!). Also, it doesn't matter if old tires are still on them or if the wheels have been removed from a machine that was on a military A10-Warthog bomb range-id be happy just to have SOMETHING I can work with or repair.
I can find the tires aplenty, but the rims/wheels have been scarce. ANY information that would aide in locating two wheels would be greatly appreciated.
Btw, I'm located in south central Missouri but have a couple weeks of vacation coming up and can travel within the contiguous United States.
Thanks in advance!
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Sat, Oct 10, 2015 4:00 AM
d9gdon
http://www.machinerytrader.com/list/dismantledsearch.aspx?ETID=3&Manu=CATERPILLAR&Mdltxt=621B&mdlx=exact
Here's a bunch of dismantled machines that will have those size wheels.
Sat, Oct 10, 2015 8:24 PM
Willowhic
Reply to d9gdon:
Thanks d9gdon!!
Excellent advice! There are even some that aren't too far away from me.
VERY much appreciated!
Sat, Oct 10, 2015 10:24 PM
| Kingaroy, Queensland
