Lack of spark
Lack of spark
Showing 1 to 9 of 9 results
2 Fingers
Send a private message to 2 Fingers
Hello all, and thank you to those who replied and helped with my previous thread. I'm still working on getting my Ten to start and run. Currently I'm experiencing a partial lack of spark. As dumb as that sounds, I am only getting spark on one wire. I've performed a continuity test on the spark plug wires and have continuity from the brushes in the magneto to the spark plug connectors. The top of the head is rusty and crusty so laying the spark plug on top of the head to ground and test spark isn't the most reliable, so I've been using an inline spark tester. I've installed new spark plugs and cleaned the connections so I'm leaning toward a ground issue between the spark plug and the head, or the brushes in mag distributor are too work correctly. I'd appreciate any thoughts on the matter.
Mon, Jul 1, 2024 6:28 AM
Catboy1
Send a private message to Catboy1
have you tried moving the wires around to see if the problem follows them?
Mon, Jul 1, 2024 6:31 AM
2 Fingers
Reply to Catboy1:
That would certainly be a good way to test the faulty ground theory. I haven't tried this as each wire is a specific length to reach a specific plug and they are run inside of a protective steel tube across the length of the head. I can try to remove the wires from the protective tube and try different wires on different plugs.
Mon, Jul 1, 2024 7:44 AM
SoCalCatMan
Send a private message to SoCalCatMan
Reply to 2 Fingers:
Does it have the original mag? Or has it been replaced with a more modern style
Mon, Jul 1, 2024 10:23 AM
2 Fingers
Reply to SoCalCatMan:
It has what I believe to be the original mag, definitely nothing modern. I've done some points and condenser systems and converted a couple to electronic ignition but I don't have a ton of experience with mags (beyond riding lawnmowers).
Mon, Jul 1, 2024 11:18 AM
8C 361
Thank you received: 12
Reply to 2 Fingers:
Maybe spark is grounding in that tube.
Mon, Jul 1, 2024 8:20 PM
2 Fingers
Reply to 8C 361:
Good morning. I went out to check a few things this morning before I went to work and it turns out I cried wolf for no reason. I set my phone up to record (because I can't crank the engine and watch for spark simultaneously) and moved the one wire that I knew was good to the spark plug on either side of it and had spark in both locations, this at least told me that the plugs were grounding to the head properly. After that I hooked all the wires up to their respective plugs and recorded each one, they all have spark. Now whether it was the difference of the dark background this morning vs the bright sunlight yesterday, or the my wife's poor eyesight, it turns out that there really wasn't a problem at all. Now my biggest problem is getting the rings to seat so I have compression, and finding a diplomatic way to tell my wife that she needs her eyes checked. Thanks to those who replied, and my apologies for the false alarm. I do wonder about new carbon brushes in the distributor though, as mine seem to be worn down and maybe not making great contact, I'd like to hear thoughts about that.
Mon, Jul 1, 2024 8:36 PM
SoCalCatMan
Reply to 2 Fingers:
Ha I wish you luck. These old crawlers can be cranky from time to time. The more people around, the more nervous they seem to get. I’ve seen brand new restored cats that crank over on the first or second pull, get a small crowd at a show and take 10 minutes to start. But that’s all just part of the fun.
Mon, Jul 1, 2024 9:43 PM
2 Fingers
You're absolutely right, they fire right up when it's just you, but won't start to save your life when everybody's watching.
Mon, Jul 1, 2024 10:04 PM
Thank you received: 59
[quote="SoCalCatMan post=257834 userid=16369"]Ha I wish you luck. These old crawlers can be cranky from time to time. The more people around, the more nervous they seem to get. I’ve seen brand new restored cats that crank over on the first or second pull, get a small crowd at a show and take 10 minutes to start. But that’s all just part of the fun.
I never thought of it as the engine was being  nervous.  I thought it was doing it's best to make the poor guy trying to start it look bad. It never fails if I don't have plenty of time if I want a tractor hauled the pony will have a fit. If I get there an hour early it starts instantly. Also agree with the more people around the worse it is.[/quote]
Mon, Jul 1, 2024 10:39 PM
| Kingaroy, Queensland
