Killefer cutting edge needed
bursitis
Anyone know where i can get a new cutting edge for a john deere killefer model 9k10-02 box scraper?
Fri, Apr 25, 2025 5:56 PM
Thank you received: 227
https://www.kencoengineering.com/wear-parts/loader-bucket-wear-parts/cutting-edges
I do not know if they can help you, however recall the name when I worked for the state, used those carbide blades on plows and loaders. I would suggest measuring the length, thickness and bolt size/spacing. Does your blade use "plow bolts - recessed heads with square shanks"? Sometimes a simple diagram or photo with that information helps, they may even refer you to another supplier.
Sat, Apr 26, 2025 1:24 AM
bursitis
Thanks for the link. Yes it uses plow bolts. I will contact them next week. Thanks again
Sat, Apr 26, 2025 12:36 PM
