In search of D6 5R/4R Starting engine Clutch and pinion
Showing 1 to 10 of 10 results
BigAgCat
Send a private message to BigAgCat
I am looking for a complete starting engine clutch and pinion assembly for my D6 5R.
I am in no rush, but if anyone has a complete one laying around to sell, I would be interested in purchasing it if the price is right.
Cat D6 5R
Wed, Mar 11, 2020 11:32 AM
gemdozer
Thank you received: 25
I have the complet cluch housing but missing the outside sleeve
Wed, Mar 11, 2020 6:20 PM
BigAgCat
Reply to gemdozer:
Do you mean the pinion gear sleeve, IF909? If not, I am not sure what you mean by missing the outside sleeve.
Cat D6 5R
Thu, Mar 12, 2020 12:53 AM
gemdozer
Reply to BigAgCat:
Yes the 1f909 sleeve is missing on but the pinion 13teeth is on.
Thu, Mar 12, 2020 5:02 AM
BigAgCat
Reply to gemdozer:
Unfortunately the sleeve and all the parts that attach and make the sleeve function as it is supposed to function is what I need most.
Though, I might consider seeing if I can find a source for the sleeve and all the parts I need for it.
Do you have a picture of what you have and a price you are looking to get?
Cat D6 5R
Fri, Mar 13, 2020 12:52 AM
BigAgCat
Reply to BigAgCat:
I am looking for the entire assembly that you see being held by the person in this photo.
[attachment=57687]WIN_20200313_10_31_50_Pro.jpg[/attachment]
Cat D6 5R
Sat, Mar 14, 2020 12:38 AM
Mschwartz
Reply to BigAgCat:
Hello, do you know if the parts from a 9u would be the same? Or how to tell the difference? Bought pony motor parts years ago from a guy that converted to electric start but that was before I knew the difference between 4R and 9U and I can’t remember what he had. I am near Lacrosse Washington if that is close to you. Mike
Tue, Mar 17, 2020 9:32 PM
BigAgCat
Reply to Mschwartz:
From what I can gather looking at the parts for the 4R/5R and 9U, the only difference with the pony starter assembly is the lever. 3b3537 for the 5R and 4f8193 for the 9U. I feel like a different lever isn't something that would make or break the ability to replace the starter clutch assembly in either of these tractors.
Cat D6 5R
Wed, Mar 18, 2020 1:52 AM
oldbeek
Reply to BigAgCat:
I assume you have found your pinion assy. I have one also in So Cal.
Sun, Mar 29, 2020 6:02 AM
BigAgCat
Reply to oldbeek:
Yeah, I have acquired what I am looking for. Though I am tempted to buy every one I can find. I feel like it is one of the weakest points of the tractor and having spares might be nice.
Cat D6 5R
Mon, Mar 30, 2020 2:07 AM
josh
Thank you received: 14
Reply to BigAgCat:
The trick with that assembly, is to learn to properly adjust, lubricate and use, they will last a very long time and work well when used as directed, they get damaged and fail if not.
Mon, Mar 30, 2020 5:33 AM
