I need one lever on the controls on a 212
Jeff M.
 I need one control lever from a 212 grader. I think it is the second one on the right side . Thanks for the help
Mon, Aug 19, 2024 7:37 PM
Jeff M.
I also need the crosses in the drive shaft from the transmission case to the control box
Wed, Aug 21, 2024 5:09 AM
Fat Dan
It is much easier to find the correct part if you cite the Part Number and Serial Number as well as the identification of the part. I don't have any manuals on any of the 212 models, I do know not all levers are made equal [img]/media/kunena/emoticons/couch2.gif[/img] A good set of Cat manuals is a must to be able to work on your own equipment. They have an excellent online library for members here at ACMOC.
Good Luck.
Fri, Aug 30, 2024 4:50 PM
Jeff M.
Reply to Jeff M.:
I also need the crosses in the drive shaft from the transmission case to the control box Ok Dan here are the part numbers the cross number is 6F 9741 The Lever number Is 5B 5184. We will see if that helps thanks for the help
Tue, Sep 3, 2024 6:26 AM
josh
Thank you received: 14
Reply to Jeff M.:
The cross was also used on the 8T and 7T graders and some other applications, so should be some around, also the levers on the 8T grader look like they might be similar enough to the 212 levers that you might be able to modify one to be a match.
Tue, Sep 3, 2024 9:58 PM
Reply to josh:
If your referring to the power control drive shaft for the 9Txxxx the u-joint crosses are a standard #UJ961
Wed, Sep 4, 2024 12:17 AM
Jeff M.
Where do you find the uj961 joints at
Wed, Sep 4, 2024 5:57 PM
Reply to Jeff M.:
Try SKF for the UJ961 or "google search" for 6F9741. They seem to be out there.
Plenty 6F9741's listed on machinery trader.
Wed, Sep 4, 2024 11:45 PM
Jeff M.
Thanks for the help I got one ordered
Thu, Sep 5, 2024 1:37 AM
