Hyster D4 Cargo Winch - fits Cat HT4???
Showing 1 to 10 of 14 results
JohnInKY
Send a private message to JohnInKY
This is an older Hyster D4 rear cargo winch that my uncle never had a chance to mount on the back of his Caterpillar HT4 before he passed. Just sitting on a cart, rusting away. Input shaft can still be easily turned by hand, so likely still good inside. I have a few pictures, but couldn't figure out how to get them off my phone into this post. It is located in Northern Kentucky. If any interest, e-mail me: [email protected]......[attachment=43863]20170624_164225.jpg[/attachment][attachment=43864]20170624_164206.jpg[/attachment][attachment=43862]20170624_164234.jpg[/attachment][attachment=43865]D4 Winch Bolt Pattern2 (1).jpg[/attachment][attachment=43869]Front View D4 Winch Input and Control shafts.jpg[/attachment][attachment=43866]SideViewWinch.jpg[/attachment][attachment=43870]TopViewD4 Winch1.jpg[/attachment][attachment=43867]Close up of number on top.jpg[/attachment][attachment=43871]Round thing with winch1.jpg[/attachment][attachment=43868]TopViewD4 Winch2.jpg[/attachment]
Fri, Aug 4, 2017 3:39 AM
d9gdon
Sent a private message
Fri, Aug 4, 2017 4:30 AM
JackD6-5R
Reply to d9gdon:
I put an old D4 winch on an HT4 several years ago, it fit and works.
Fri, Aug 4, 2017 7:24 PM
d9gdon
Reply to JackD6-5R:
I was looking at the instruction manual for this winch and it says not recommended for D4 6U and 7U tractors. What is the reason for that?
I know that the HT4 was just a D4 7U with a loader attached.
Anybody know why? It has more line pull than what the 6U and 7U weigh.
Sun, Aug 6, 2017 7:58 AM
STEPHEN
Reply to d9gdon:
The later tractors would have used a D4N. From memory, there are some mounting and control changes. Could be the early type is not suitable for a higher HP engine?
Sun, Aug 6, 2017 11:15 AM
d9gdon
Reply to STEPHEN:
In the same book, there was an attachment option to fit it to a D6 so I don't think it could be the horsepower rating of the later D4's.
Sun, Aug 6, 2017 8:26 PM
STEPHEN
Reply to d9gdon:
That attachment would be a great find, please share a pic from your book - thanks
Sun, Aug 6, 2017 8:59 PM
Reply to STEPHEN:
I don't think horse power has anything to do with the limitations although the D4N is a bit stouter. I believe they are just referring to the control mounting hardware differences between the D4 and D4N as a reason to exclude the 6U/7U's. Interesting in that the 4N can be retrofitted to the models R4, RD4, D6, RD6, 35's and 40's. Probably due to a simple control system.
Mon, Aug 7, 2017 12:08 AM
d9gdon
Reply to JackD6-5R:
Did you have to modify anything for it to fit?
Mon, Aug 7, 2017 6:02 AM
JackD6-5R
Reply to d9gdon:
Yes I did have to make a few mods. Had to raise the seat ,think I used 2 pieces of 2X2 square tube under seat mounts to clear the fwd. & rev. control. Some changes to the brake control ,but I cant remember what.
Tue, Aug 8, 2017 2:06 AM
d9gdon
I sent a PM and an email.
Wed, Aug 9, 2017 3:58 AM
