Holt 10 ton piston
Holt 10 ton piston
farquharmike
Send a private message to farquharmike
I am finally getting started on a 10 ton project and havs a piston with a cracked skirt. I am in need of a piston, or does anyone know if one out of a 45 engine will work. I was told some parts are the same.
Mon, Dec 14, 2015 8:47 PM
WyoCat
What vintage is your 10 ton? That will help us help you.
Chad Enyeart
Mon, Dec 14, 2015 9:28 PM
farquharmike
Reply to WyoCat:
I am not sure how to tell the vintage. It came to me in pieces, and I have not found a serial #. My best guess from the information I have would be a later Holt.
Tue, Dec 15, 2015 3:05 AM
WyoCat
Reply to farquharmike:
Does this engine have valve covers?
Chad Enyeart
Tue, Dec 15, 2015 3:44 AM
farquharmike
Reply to WyoCat:
Yes it does have valve covers
Tue, Dec 15, 2015 8:26 AM
WyoCat
I believe that the late 10 ton engine is a larger bore than the early 10 ton/holt 45 engine. Post a picture of your piston and its diameter. I will see if I can match it up. Also check it inside and out for a casting number or stamped part number.
Chad Enyeart
Wed, Dec 16, 2015 7:26 AM
| Kingaroy, Queensland
