fuel filter part
fuel filter part
Showing 1 to 9 of 9 results
handhewn
Send a private message to handhewn
I need the part in my fuel filter in my 1937 D6 that is between the canister itself and the top of the fuel canister that holds the 6 filters. Part # 6B2342. This is the part that actually holds the six filters. It is approx. 6 in. by 6 in. and a little over a quarter inch thick. It is plastic but that surprised me. I expected it to be metal. Is the metal original or is this a replacement? This peace cracked and leaks fuel badly. I am in Northern Calif.
Mon, Mar 20, 2017 9:33 PM
Thank you received: 62
The original element was a series of brass screens that were cleaned and reused. You are dealing with a later up graded system. Most likely a Cat product but could even be something else. Been a long time since I have dealt with the the Cat up date but would think 4 elements would of been what was used as that is what was in the more horsepower in engine later D6.
Unless someone with better knowledge comes along I would look for a D7 or D8 fuel filter canister and start measuring and hope for the best.
Mon, Mar 20, 2017 10:23 PM
Reply to Ray54:
Same plate in a 9G6325-up D7. D8's have more elements.
I seem to recall a post on here about duplicating the plate using aluminum
Mon, Mar 20, 2017 10:55 PM
handhewn
[quote="Old Magnet"]Same plate in a 9G6325-up D7. D8's have more elements.
I seem to recall a post on here about duplicating the plate using aluminum[/quote]
Mine is a 6 filter type using the wrapped twine type filter, not the stacked thin metal wafer filter type. I have this part for D8 (nine filters) and the four filter type for D4. Neither will work here. If I can not find one I will have to make one. Would aluminum be what I should make it out of? It looks to be a simple job (famous last words)
Tue, Mar 21, 2017 1:54 AM
brian18a
Thank you received: 69
Reply to handhewn:
Florin Tractor has one.
Tue, Mar 21, 2017 2:04 AM
STEPHEN
I made the alum one for a D8800 power unit
Tue, Mar 21, 2017 7:33 AM
STEPHEN
Reply to STEPHEN:
If your plate is as swelled as mine was, then don't measure the old plate for the hole dimensions, measure the studs and figure from there.
Tue, Mar 21, 2017 7:41 AM
handhewn
Reply to STEPHEN:
Thanks guys. I'll try florin tractor. If I don't like their price I'll make one. It does not look to be too tough to make one.
Tue, Mar 21, 2017 9:13 PM
STEPHEN
Reply to handhewn:
They had on last year for $100.00
Wed, Mar 22, 2017 7:47 AM
handhewn
Reply to STEPHEN:
I phoned Florin Tractor and they do have one for $75. Not a bad price but it only took me a couple hours to make one as I had all that I needed to do the job. Now to see if it works.
Wed, Mar 22, 2017 9:43 PM
