Equalizer Bar 1939 D2 3J
Showing 1 to 7 of 7 results
JDP
Send a private message to JDP
Looking for an equalizer bar for a 1939 D2 3J and all associated hardware to bolt it on...currently my cat has a piece of ibeam in place of the leaf spring system which I would like to get rid of before it cracks my oil pan...
Sat, Mar 9, 2013 9:01 AM
chriscokid
if no one has one available i can get you the dim. so one can be made at a truck spring company.
Sat, Mar 9, 2013 10:24 AM
josh
Thank you received: 7
Reply to chriscokid:
Where are you located, those springs are pretty heavy.
Sat, Mar 9, 2013 11:45 AM
JDP
Reply to josh:
Josh - Located in Alberta Canada
Chriscokid - Can you give me the dimensions? I'll price out a new one and see if its going to be comparable to buying a used one and getting it shipped to me
Sat, Mar 9, 2013 12:25 PM
chriscokid
Reply to JDP:
I will be glad to , please give me a few days but i will get them for you.
Sun, Mar 10, 2013 3:49 AM
JDP
Sounds good, thank you!
Sun, Mar 10, 2013 11:58 PM
mjp
Send a private message to mjp
Reply to JDP:
parts book shows a few diferant stiles mine has 10 springs ithink a xtra was added also has 4 ubolts dont have the nuts for the 2bolts that hold to engine
everything else seems to be there cost to ship 175 to 215$ wt is about 75# i think maybe someone closer maybe able to help for les money help anyone?
thanks mike
Thu, Mar 21, 2013 6:31 PM
steamdrum1
Send a private message to steamdrum1
Reply to mjp:
thanks mike
Give Jim Zimmerman a call 641-982-4207 He has a Caterpillar salvage yard in Orchard Iowa, and is very nice to deal with. Next closest I can think of would be Zimmerman Tractor in MO. I don't have thier number handy, but google them and it comes right up.
I just went through the same thing on my wide gauge Thirty. Someone had replaced the spring with an I beam. I was lucky enough to find a junk Thirty about 50 miles from home, it had the main and pony springs plus all the hardware. I had a local spring company make the couple springs that were damaged. Good Luck Bill
Fri, Mar 22, 2013 7:11 AM
