Early fuel pressure and oil pressure gauges wanted
Showing 1 to 9 of 9 results
td-alan
Send a private message to td-alan
I am looking for restorable oil and fuel pressure gauges for my D5 restoration , I prefer the sylphon gauge but would consider a set of the Ashcroft gauges as well . The gauges I’m looking for could be found on D2 -D8 tractors . Thanks Alan
Mon, Jan 15, 2024 9:19 AM
brewzer
I have the Sylphon gauge. It is in excellent condition and works. I also have Ashcroft
Wally
Mon, Jan 15, 2024 10:32 PM
brewzer
Reply to brewzer:
Wally
I sent you a PM.
Mon, Jan 15, 2024 10:40 PM
Floyd Green
Send a private message to Floyd Green
Reply to brewzer:
I sent you a PM.
How does one determine the maker/age? I'm sitting here with (I think) an old CAT fuel pressure gauge but I really have no clue. I can find no part# but there is a small "SW" under the glass at the bottom. I have two oil pressure gauges on each of two 1930s CAT "POWER UNIT" set-ups out in a field.
Tue, Jan 16, 2024 8:58 AM
td-alan
Floyd green , the sw on your gauge means that Stewart Warner company built that gauge .
The “sylphon “ gauge has it written on the face as well as the Ashcroft
Tue, Jan 16, 2024 9:26 AM
Thank you received: 35
Reply to td-alan:
Wally, do you happen to know the models that the Sylphon were installed on (or at least had the Sylphon name written on the gauge face plate). I have a damaged fuel pressure gauge in my 3J and an aftermarket oil pressure on my 5U that I'd like to return to the more traditional look
Tue, Jan 16, 2024 9:59 PM
brewzer
I have no literature to back this up but I am pretty sure that the D2s used the sylphon style that showed a range rather than the 0-50 gauge tha came on the earlier gas tractors.
Wed, Jan 24, 2024 5:53 AM
Reply to brewzer:
Thanks Wally, did Sylphon also make ammeters? I have an aftermarket ammeter and it just doesn't suit
Fri, Feb 9, 2024 5:22 AM
brewzer
Not that I'm aware of.
Fri, Feb 9, 2024 10:21 PM
GrantJ
Thank you received: 6
Reply to brewzer:
There is a company that restores gauges and instruments. Mostly for aviation but will restore any type. .
Fri, Feb 16, 2024 11:55 PM
