D9 Tilt Cylinder and Drawbar Wanted
Showing 1 to 10 of 12 results
Willowhic
Send a private message to Willowhic
I'm interested in purchasing a tilt cylinder and potentially a drwbar for my D9. Any information about these or where to locate them would be appreciated. Base tractor is a 66Axxxx sn. I'd welcome a ripper in lieu of a drawbar and would be willing to purchase what's left of a whole hydraulic machine if the deal is right.
Thanks,
-nate
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Sun, Jan 10, 2016 10:17 PM
Willowhic
ANY leads would be welcome. Even if a general request for D9 parts is put in the back of your mind, I'd appreciate it very much.
Thanks,
-nate
Sun, Jan 17, 2016 9:31 PM
u-joint
Send a private message to u-joint
Reply to Willowhic:
Thanks,
-nate
he shows a 9. cannot tell in the two pictures if it has what you are looking for?
http://www.tractorparts.com/cat.htm
Mon, Jan 18, 2016 2:25 AM
Willowhic
Reply to u-joint:
Thanks ujoint!
I sent them an email request - also found a Cat 235 on their website. Hopefully their prices will be reasonable.
Much appreciated!!!
-nate
Mon, Jan 18, 2016 3:21 AM
d9gdon
Reply to u-joint:
Here's some that are torn down for parts:
http://www.machinerytrader.com/list/dismantledsearch.aspx?pg=2&ETID=3&Mdltxt=D9G&Manu=CATERPILLAR&mdlx=exact&bcatid=4&Pref=0&Thumbs=1
Off Road Equipment in Alcoa, TN would be able to source used parts also. You need part numbers. I've got the books here somewhere but would have to look to find them.
Mon, Jan 18, 2016 3:29 AM
hicrop10
Reply to d9gdon:
Nate,there is a boneyard in western pa that is located in the coal region of pa.M sure they would have what you r looking for.They go under the name of Clark Enterprise, I think they are right off of rt 80.
Mon, Jan 18, 2016 5:06 AM
JoeG
Send a private message to JoeG
Reply to hicrop10:
Clarks is north of I80. The Barkeyville exit, Rt 8 North. They are on the east side of Rt 8.
Mon, Jan 18, 2016 5:22 AM
Willowhic
Reply to JoeG:
D9gdon, Thanks for the link! Looks like a trip to Celina, TN might be in my near future.
Hicrop10 and JoeG, I wouldn't have known about Clark Enterprises or their location if you hadn't shared this info. Very much appreciated! I'll see if I can get a hold of them and find out what they have available.
Thanks again!
Mon, Jan 18, 2016 10:16 AM
Willowhic
Reply to d9gdon:
I forgot to mention that I've got a parts book and a service manual for my 66A. Thank you for the offer to locate PN's- it can be a tedious task so it means a lot to me. Thanks again!
-nate
Mon, Jan 18, 2016 10:20 AM
Reply to Willowhic:
-nate
I have parts books on the D9 rippers (several types) and the #179 Hydraulic Controls if you need info.
Mon, Jan 18, 2016 1:51 PM
Willowhic
Thanks O.M.!!
I'll be sure to send you a pm if/when I get the ripper. Very much appreciate the help!!
(Sorry for the late response-I got swamped at work the past several days.)
Tue, Jan 26, 2016 9:39 AM
