D7 3T Sheave Block
D7 3T Sheave Block
Showing 1 to 10 of 11 results
Prospectorgav
Send a private message to Prospectorgav
Hi club members, I am after a sheave wheel for a D7 3T sheave block. The Cat part number is 1J1150 (no longer available). I have sourced the bearings through Westrac in Australia for the rebuild but have one sheave pulley flogged out on the internal bearing surface. I am after just the wheel as freight to Australia for a complete block if available is expensive.
Mon, Oct 10, 2016 4:50 PM
Andrew
Not sure exactly what you are looking for but I probably have what you need.
Mon, Oct 10, 2016 5:20 PM
Prospectorgav
Reply to Andrew:
I'm after one of the pulleys that fit into the sheave block. The internal bearing surface measurement should be around 3.8750 inch in new condition. A bit of wear would be OK as this is not critical for the rope lifting the blade in its operation.
Tue, Oct 11, 2016 4:16 AM
Andrew
Reply to Prospectorgav:
OK. Just so I know what to look for , what is the dia of the pulley . also the width.
I take it you are in WA some where..
Tue, Oct 11, 2016 8:12 AM
Prospectorgav
Reply to Andrew:
These sheave blocks are on the front of the early dozers for raising and lowering the blade with a friction winch of the front of the crank. They are genuine Caterpillar parts. The pulley size is 9 5/8'' outside diameter, 1 1/4'' wide and a 3.870'' hole in the centre in which the bearing runs against which will be hardened. The original Cat part number is 1J1150. I am in Western Australia.
Tue, Oct 11, 2016 11:41 AM
Andrew
Ok. Sounds like you have a Steelweld front mounted power control unit.
I will try to have a look tomorrow.
A. K.
Tue, Oct 11, 2016 5:37 PM
Wholland
Send a private message to Wholland
Reply to Andrew:
A. K.
I think I might have two complete spares. I'm located in Texas.
Cell 713-806-8511
Wed, Oct 12, 2016 4:56 AM
Thank you received: 61
Reply to Wholland:
Cell 713-806-8511
Plenty of those sheaves around, just maybe not in Aus.
Wed, Oct 12, 2016 6:18 AM
Andrew
Couple of options here!!
Haven't done any measuring yet. Probably best to give me a ring first to see if it is worth spending more time on.
0428717065
A. K.
Wed, Oct 12, 2016 8:35 AM
Prospectorgav
Reply to Andrew:
0428717065
A. K.
I have a few options here.
I have checked out the link Old Magnet posted on the heavy equipment forum with Machinery trader who list several suppliers of pulleys (Cat 1J1150). I am awaiting a reply from them if I can get a new pulley.
The third photo you listed Andrew looks similar to the sheave block I have.
Wholland, I am having trouble sourcing a second inner cone (part No. 3F3874) for the bearing in the pulley. You have two pulleys complete, is this with the bearing? Are they new or used as I would not mind having a spare wheel on hand.
Wed, Oct 12, 2016 4:52 PM
http://www.machinerytrader.com/list/partssearch.aspx?partnum=3F3874&pst=starts
Thu, Oct 13, 2016 1:07 AM
