D7 3T #16602. WTB electric starter for pony motor.
Showing 1 to 10 of 12 results
goldminer7759
Send a private message to goldminer7759
I am looking for an electric starter for the pony motor on my 3T. Ran a 3T in the mid 1980's that had this option so I know there were some out there. Any information on specs, part numbers, or other relevant points would be much appreciated.
Thanks!
Thu, Feb 20, 2014 8:25 AM
daron
Where are you mining (western states?)?
Daron
Thu, Feb 20, 2014 9:53 AM
goldminer7759
Reply to daron:
Daron
No longer mining. Lived and mined in the Forty-Mile district for three years 1983-1985. Squaw Gulch off of Canyon Creek. Then moved across the Canadian border to the Sixty-Mile area in the Yukon Territory and mined on Little Gold and Glacier Creeks for six more years. Got out after the 1991 season. High fuel prices and falling gold prices ended my mining days. I use my current 3T for fire breaks and road maintenance on a family farm in southern Georgia now.
Thu, Feb 20, 2014 10:18 AM
Reply to goldminer7759:
goldminer,
Your looking for a starter group 3F9277 or 3F9549
Thu, Feb 20, 2014 2:02 PM
goldminer7759
goldminer,
Thank you! The number will help me track one down.
Thu, Feb 20, 2014 6:30 PM
goldminer7759
I can find no info on the two numbers 3F9277 & 3F9549. Through more digging I came up with 6B9157 & 6B9158. These two numbers are the actual starter and the cast housing that bolts onto the pony motor. If anyone could provide any other details about this I would be very appreciative!
Thanks,
goldminer7759
Fri, Feb 21, 2014 9:18 PM
Here are the starter groups. Complete systems with/without battery and 18 or 40 amp generators with or without lights are yet different group numbers.
Fri, Feb 21, 2014 10:52 PM
goldminer7759
Thank you both very much! Makes things very clear. Back to the finding now.
Fri, Feb 21, 2014 11:07 PM
ag-mike
What does 3f9272 tube assembly and fitting do? i have come up with this cast mount and starter for my d13000 pony, how r you suppose to use these to crank the pony? Whats with that solenoid lever being up against the bolt head? Haven't installed it yet.
thanks 4 any help.
Sat, Feb 22, 2014 8:28 AM
josh
Reply to ag-mike:
thanks 4 any help.
Mike,
3F9272 is a water drain tube for the starting assembly. That bolt head on the solenoid lever is an adjustment on the end of the shaft that engages the starter solenoid at the same time as the gear to the starter.
Sat, Feb 22, 2014 9:56 AM
ag-mike
Reply to josh:
Mike,
[quote="josh"]Mike,
3F9272 is a water drain tube for the starting assembly. That bolt head on the solenoid lever is an adjustment on the end of the shaft that engages the starter solenoid at the same time as the gear to the starter.[/quote]
i looked at that bolt and how it works with the engagement handle. I assume the gear b fully engaged (4 sure) to flywheel b4 the bendix kicks in.
thanks.
Sat, Feb 22, 2014 10:12 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
