D6C
MTD2
Send a private message to MTD2
Wanting to know if someone knows of a full U blade for a D6C. Not sure, but maybe the full U off a D6D would work also. Has to be one sitting under a tree somewhere! Thanks.
Sat, Aug 9, 2025 12:27 AM
tenncat
Send a private message to tenncat
Considering a full U blade is designed for a tractor that pushes large amounts of a material most of the time, my first thought is that no one made a full U for a D6C. These were usually found on a D8 and larger. After looking in a Caterpillar reference book I found that Cat did not make one, only a semi-U blade for a D6.
Your only other option would be someone like Balderson or Rockland made one.
Good luck.
Thu, Aug 28, 2025 7:00 PM
MTD2
Thanks tenncat, it will be hard to find. I ran one that the county used to have. It was a very nice D6C with a full U dozer and factory ripper. It sure could be the vintage of a Balderson blade. I have seen 2 others, one on a D6D that a neighbor has, and one in South Dakota. I have a full U for a D7, would fit a 17A, but has mounts for both cable and a hard nose.
Sun, Oct 5, 2025 4:00 PM
