D69U exhaust elbo, pony motor
Showing 1 to 6 of 6 results
fred hogan
Send a private message to fred hogan
My exhaust flange coming out in front of the main motor intake broke in three pieces. Where can I get another one, or some kind of aftermarket flange?? flyingfred
Mon, Sep 2, 2019 9:33 PM
gemdozer
Thank you received: 25
Let me have the part number so could checkif am still have one
Tue, Sep 3, 2019 12:52 AM
fred hogan
Reply to gemdozer:
my book is showing part # 4F7631
Tue, Sep 3, 2019 9:45 AM
gemdozer
Reply to fred hogan:
Sorry do't have the pipe
Wed, Sep 4, 2019 5:49 AM
oldbeek
Reply to gemdozer:
I bumped my exhaust stack coming out of the intake flange and broke it. Fitted the pieces back together with chamfers ground in them and brazed them back together. Brazing is easy if you buy some good flux. Holding up nicely. Try it.
Wed, Sep 4, 2019 6:28 AM
Thank you received: 62
Reply to oldbeek:
From my experience brazing is not the best. For what ever reason I like running the alweld brass gas welding rod. Used to do a lot tin work on combines with it. So I used on 9u pony exhaust went together well. Started cracking apart very soon. Old experienced independent mechanic spots my work and informs me,he has never seen brazing last over time. His explanation was the brass gets brittle over time from heating and cooling cycles. So may last for today's hobo use compared my 6 days a week 35 years ago.
I would think today a small mig would be a good option. As well as die grinder with wire wheel to clean rust off real good.
Wed, Sep 4, 2019 11:50 PM
fred hogan
Reply to Ray54:
[quote="Ray54"]From my experience brazing is not the best. For what ever reason I like running the alweld brass gas welding rod. Used to do a lot tin work on combines with it. So I used on 9u pony exhaust went together well. Started cracking apart very soon. Old experienced independent mechanic spots my work and informs me,he has never seen brazing last over time. His explanation was the brass gets brittle over time from heating and cooling cycles. So may last for today's hobo use compared my 6 days a week 35 years ago.
I would think today a small mig would be a good option. As well as die grinder with wire wheel to clean rust off real good.[/quote]
my brother is good with tig….the flange is more oil coated and carbon than rust.....I found Ford tractor elbow for around $30, but it's a little too big, ( 1 and 5/8 ), and I need 1 and1/4....
Thu, Sep 5, 2019 8:29 AM
