D69u
Showing 1 to 10 of 14 results
arlash
Send a private message to arlash
Looking for vertical caterpillar metal name tags for D69U
Mon, Feb 3, 2014 11:17 AM
Thank you received: 63
Are you referring to the "Caterpillar" and "D6" on the radiator side plates?
They are cast in, not a separate tag.
Mon, Feb 3, 2014 1:41 PM
arlash
The later model cat 9u have metal name plates. I have two rusted out ones that came off my D6 9u.
Mon, Feb 3, 2014 10:09 PM
Reply to arlash:
Do you have part numbers. My 1973 printed parts book shows cast side panels 9U28320-up. Don't recall ever seeing separate tags.
Tue, Feb 4, 2014 12:04 AM
agibson396
Send a private message to agibson396
[attachment=21487]D6 9U.jpg[/attachment]
Our D6 s/n 9U24529 has the riveted on nameplates as well. As Old Magnet indicated, our parts manual also only shows the stamped model.
Tue, Feb 4, 2014 4:01 AM
chriscokid
Reply to agibson396:
D6 plate is here: http://www.tractorparts.com/crawlerplates.htm
they might have a good used "caterpillar" plate as well.
Tue, Feb 4, 2014 6:38 AM
Reply to chriscokid:
Why not change out the side panels for the cast versions?
Tue, Feb 4, 2014 7:23 AM
arlash
I could not find the name plates in a number of parts books i looked through. My D6 s/n is 9u19383. I believe they are discontinued my Caterpillar. They seem to rust out pretty quickly at least they do along the Pacific coast. I really believe that the cast name plates are earlier D6 tractors. I want to thank everybody for their help.
Tue, Feb 4, 2014 9:38 AM
u-joint
Send a private message to u-joint
Reply to arlash:
what is the length? I have a few.
Tue, Feb 4, 2014 10:35 AM
u-joint
Reply to u-joint:
I have a pair at 16.75 long and another pair at 23.50 long.
Tue, Feb 4, 2014 11:10 AM
u-joint
Reply to u-joint:
the plates go on the hard nose equipped tractors.
Tue, Feb 4, 2014 11:11 AM
