D6600 magneto
D6600 magneto
Showing 1 to 10 of 11 results
657cat
Send a private message to 657cat
I was wondering I& anyone had a hot mag for a RD6 or a D6600 that the6 wanted to sell?
Sat, Jun 6, 2020 9:46 AM
oldbeek
D4600 ? Mag stands straight up? Have one off a 9k cat 12.
Sat, Jun 6, 2020 12:36 PM
Mike Meyer
Thank you received: 6
Reply to oldbeek:
oldbeek, the RD6 mag hangs upside down, I reckon it's a Eisemann RC-2Q, someone will confirm
Mike
Sat, Jun 6, 2020 2:55 PM
Reply to Mike Meyer:
Mike
That is correct.
Sat, Jun 6, 2020 10:23 PM
657cat
That is correct.
Yup that’s right. I have 2 Eisemanns but I don’t think I have enough parts between the two to get a functional one. My RD 6 has a Fairbanks Morse on it. Not sure of the type. I am actually needing this one for my 11 grader.
Sun, Jun 7, 2020 12:05 AM
gemdozer
Thank you received: 25
Reply to 657cat:
I dismantled 3 magnetos EISEMANNS with a small lever on side maybe could help with parts.
Sun, Jun 7, 2020 4:59 AM
657cat
Reply to gemdozer:
Well I have a good cap that uses a rotor like a distributor. But I don’t Have the rotor. The other cap I have has brushes and is badly corroded. I have 2 good rotors for that cap. My points are good. I also think my coils are good. About 7k ohms and don’t test like they are shorted. I am not sure about the condenser.
I can use a cap or rotor to give me a good set. A coil if you have one that the casing is not split. And if you have a good condenser I will take that as well.
Let me know what you have.
Thanks BJ
Sun, Jun 7, 2020 6:25 AM
gemdozer
Reply to 657cat:
Thanks BJ
I check today and have 1 condensor and rotor and have a cap but when I clean it for checking if he was't crack I found a small hole on no luck.
HECTOR
Mon, Jun 8, 2020 2:38 AM
657cat
Reply to gemdozer:
HECTOR
What rotor do you have? The flat style that goes with the cap that has spring loaded brushes?
Mon, Jun 8, 2020 3:09 AM
josh
Thank you received: 14
Mike
My books are showing the RD6 using either the Eisemann GV2Q or the Eisemann RT-2Q.
[quote="Mike Meyer"]oldbeek, the RD6 mag hangs upside down, I reckon it's a Eisemann RC-2Q, someone will confirm
Mike[/quote]
Mon, Jun 8, 2020 1:32 PM
gemdozer
Reply to josh:
Mike[/quote]
My distributor rotors parts number 9b8027 (EISEMANN 23185)and the condenser 9b8079 =22-910
Tue, Jun 9, 2020 12:17 AM
