D6 Magneto Wanted
D6 Magneto Wanted
Wanted: Operational or rebuildable core D6 Magneto. American Bosch Model MJK 4/2 360 (A, B, C, or D) 410. Impulse coupling stamped "30*"  "HG73212".
Thanks,
Jeff
Mon, Aug 7, 2023 2:18 AM
gemdozer
Thank you received: 25
I have a AMERICAN BOSCH magneto with coupling HG73212
Tue, Aug 8, 2023 4:46 AM
Reply to gemdozer:
What's the model number?
Thanks,
Jeff
Wed, Aug 9, 2023 1:05 AM
gemdozer
Thanks,
Jeff
I am sorry the small plate indentification on side is't on but he is cluck side
Wed, Aug 9, 2023 2:30 AM
Reply to gemdozer:
Thanks. I'll consider it. Before you quote a price, keep this in mind. I will have to treat it as a rebuildable core. I bought a D8 mag from you several months ago, and it did create a spark on the bench, but failed to spark under compression in a mixture, which requires higher voltage. I found the coil and condenser tested below spec and had to replace both for a bit over $100 to make it functional. Please let me know what your price is and I may go ahead with it.
Thanks,
Jeff
Wed, Aug 9, 2023 2:41 AM
