d6 engine lifting eyes
Showing 1 to 10 of 11 results
monserandsons
Send a private message to monserandsons
im looking for a pair of lifting eyes for a d318 like pictured in the servicemens referance book. including the nuts with spacers. i would have had my engine out today but couldnt decide on appropriate lifting arrangement
Sun, Mar 27, 2016 7:25 AM
Thank you received: 95
scan below may help. This is what we used at the Dealer for all D315/D318 engine applications--plus anything else it may fit safely.
Sun, Mar 27, 2016 9:26 AM
monserandsons
Reply to edb:
thank you, i have the stuff to make that
Sun, Mar 27, 2016 10:42 PM
monserandsons
Reply to monserandsons:
can i put this directly to the covers and then just snug the plate down to the covers or do i have to remove the covers and have a nut above and below the channel? thanks again for your time
Mon, Mar 28, 2016 7:15 AM
Hi,
we used to remove the nuts and the sealing aluminium washers and fit the bracket on the studs without removing the covers. The studs were long enough to do this in my experience, we usually used flat washers over the slotted holes in the bracket for safety.
Mon, Mar 28, 2016 9:26 AM
Reply to edb:
Hi,
any idea on the weight of a D318 engine?
Tue, Mar 29, 2016 12:29 AM
Reply to dpendzic:
Hi Dan,
by two different spec. sheets here I see around 3100lbs dry weight for a basic engine, do not know what if any attachments may be on it to be more accurate for you.
Someone else may have more definite figures.
Tue, Mar 29, 2016 7:25 AM
Reply to edb:
Hi Dan,
Thanks Eddie---that will give me a ballpark number to check the rigging I need!
Tue, Mar 29, 2016 7:44 AM
STEPHEN
Reply to edb:
Hi Dan,
I like the channel style beam, will have to make one. Here is a bit of rigging I made to lift a D8800. Used trailer D rings and some heavy angle.
Tue, Mar 29, 2016 7:47 AM
ag-mike
Reply to edb:
[quote="edb"]Hi Team,
Eddie B.[/quote]
does this work with the radiator attached?
Tue, Mar 29, 2016 9:09 AM
old-iron-habit
Reply to edb:
Eddie B.[/quote]
My Uncle Hurley had a lifting bar like in your scan. Where you have the lifting chain holes he attached 2 large turnbuckles connecting the other end to the common hoist point. By twisting to adjust one or the other turnbuckles he could adjust the levelness of the engine for mating up.
Tue, Mar 29, 2016 1:44 PM
