D4D S.N. 22C000342
D4D S.N. 22C000342
MLF 7979
Send a private message to MLF 7979
Does anyone know if 4S-8500 is the correct block in this D4D . Looking for a Block trying to save this this old Cat. Found a lot of 7-4300 will this block switch out with my 22C000342?power shift model. Thanks MLF
Sun, Dec 28, 2025 12:36 AM
Thank you received: 32
7-4300 is not a good number. If you mean 7M4300 then yes the block is interchangeable with 4S8500.
Sun, Dec 28, 2025 6:00 PM
MLF 7979
Thanks Old Magnet yes 7-M 4300 what I ment. Thanks again for the information. Haven’t got the old motor pull yet just trying to make sure my everything would change out especially the oil cooler for power shift.
Sun, Dec 28, 2025 7:59 PM
Also other candidate block casting numbers:
4M5400, 7M4301, 7M4302, 7M4303, 8M4900, 5S4129
Sun, Dec 28, 2025 8:29 PM
MSTEC STEAMFEST
