D4d 22c401
TOWNSENDQ
Send a private message to TOWNSENDQ
Hi i'm in search of a belly pan for d4d 22c, and also what is the good and the bad for the early powershifts, what should i look out for?
I also have a d6 9u with siezed engine, engine was rebuilt but siezed from sitting, any suggestions, i've poured diesel into air intake and exhaust manifold, then took valve covers of and opened all valves which weren't with a hammer handle to allow diesel to flow into them. Last i checked it was still locked up. I thnik my next option is to pull the head off.
I'm located in east central sask.
Pic of my d4d 22c
[attachment=45762]d4d.jpg[/attachment]
Mon, Nov 27, 2017 5:10 AM
bursitis
you should move the D6 question to the General forum so more people will see it. i have a neighbor that uses the hydraulic pressure from his tractor through an adaptor made from an old injector to free stuck engines. seems to work well.
Mon, Nov 27, 2017 9:13 PM
TOWNSENDQ
Reply to bursitis:
Thats a good idea i wonder wear he tied in the hydraulics to the head?
Moved post to discussion
thanks
Mon, Nov 27, 2017 9:33 PM
Thank you received: 19
Reply to TOWNSENDQ:
thanks
No issues with the powershift that I'm aware of. Early unit in a long line of the series. Pay attention to heating and cooling on the D330a as they are known for cracking heads.
Tue, Nov 28, 2017 12:04 AM
