D4c 40a wet clutch oil pump
mp3953
Send a private message to mp3953
My oil pump went out. Looking to see if someone has a wet clutch sssembly or oil pump alone that they are willing to part with. Thanks ahead of time.
Sun, Oct 4, 2026 3:15 PM
Thank you received: 62
I am very much out of fixing much but a few years ago, it was Cat, or Regel Corporation for after market parts. Local to me as part of the Quinn Cat dealerships is their used parts at Parts Depot.
Mon, Oct 5, 2026 3:28 PM
d4e
Send a private message to d4e
I use to Get scavenge pumps from Utah track and welding for my D4 Es just make sure you get the aftermarket drive gear for it as well a Cat drive gear and aftermarket pump Do not mesh
Sun, Oct 11, 2026 9:20 PM
gemdozer
Thank you received: 25
If you could have some parts number maybe I could help
Sun, Oct 11, 2026 10:57 PM
Thank you received: 65
That's a 4H7498 pump and 1H8438 drive gear (25T)
Mon, Oct 12, 2026 12:33 AM
gemdozer
I should have the cluch oil pump and gear
Mon, Oct 12, 2026 1:19 PM
