D4400 engine parts
D4400 engine parts
mal. f
Send a private message to mal. f
hi all we are down under in NZ im looking for caterpillar #10 auto patrol grader engine parts mostly gasket liners and rings if any one has them for sale
engine serial# 5H 610-SP Power unit please send back email to [email protected]
Tue, Sep 30, 2025 10:29 PM
Thank you received: 78
Hi Mal, Cat still stocks some parts although I think Goughs now only keeps parts in the Auckland warehouse and if not there, then Melbourne and if not there, then Singapore. Piston rings are probably more easily sourced from JP Pistons in Oz - they also do pistons if you need them. Liners I don't know about but Cat can likely do some of the gaskets. Since you're talking liners, then you might be thinking head gasket and sump gasket. The head gasket may be reusable - many were from that era. Sump gaskets and others like it may be available from Cat or many folks just get a roll of gasket paper and cut them out. Where are you located in NZ? I have a Twenty Two in Masterton, a friend has a D2 in Timaru, another fellow has a good range of units north of Auckland. I also know of a #11 with the D6100 engine (3 cyl diesel) in Masterton but am not aware of any other Auto Patrols in NZ. Someone on here will know what tractors share the same engine as the #10. I'm going to guess at a Twenty Eight or something like that, but are you writing that yours has a D4400 in it? If it does, more parts are available from Cat (not liners though, I'm pretty sure)
Wed, Oct 1, 2025 8:12 AM
mal. f
hi neil
i sold a twenty two a few years ago it was a rear one i was told it had a factory blade and was electric start
Mon, Oct 6, 2025 2:23 AM
I'm pretty sure it won't have been a factory blade since Cat didn't start making their own attachments like blades etc. until much later than the Twenty-Two's availability. More likely it would have been aftermarket. This 22 here has a blade of local manufacture. The starter motor though was a factory option. I've never personally seen one on a 22 so I'd love to see photos if you have any still. Where are you located? Currently in Mstn and heading back stateside on Thurs
Fri, Oct 17, 2025 10:49 PM
