D4 5T Hyster Wench
D4 5T Hyster Wench
Showing 1 to 10 of 33 results
M00051
Send a private message to M00051
May buy this. Will the rear sprockets fit a 7U? What's under or behind D4 5T Hyster wench to drive it?[attachment=34781]image.jpg[/attachment]
Fri, Apr 8, 2016 2:22 PM
Wombat
Donor
Money, passion and lust are main drivers for any wench :censored:
Fri, Apr 8, 2016 6:04 PM
Wombat
Donor
Reply to Wombat:
The winch is driven off the output shaft (pto) on back of transmission.
Fri, Apr 8, 2016 6:09 PM
7upuller
Reply to Wombat:
Hey Wombat,
What's on your mind??? :censored: hahaha...:bounce:
Fri, Apr 8, 2016 9:10 PM
M00051
Reply to 7upuller:
Hey Wombat,
So there's an actual PTO that that could be used for implements on my D4 7U because I'm not interested in the wench there's no cable on it. What I was interested in was the tracks and rear sprockets if they would fit my D4 7U because there not quite as worn as mine. The engine unfortunately the engine is full of rain water.
Fri, Apr 8, 2016 9:26 PM
RayMiller4288
Send a private message to RayMiller4288
Reply to M00051:
Where are u located and how much do u want for the wench? Thank you
Fri, Apr 8, 2016 10:35 PM
Thank you received: 50
Reply to M00051:
They all have a stub shaft to drive an attached pto, winch, pump, etc. You just have to add the attachment.
Tracks and sprockets are the same for the 5T and 6U/7U D4's.
Fri, Apr 8, 2016 10:40 PM
d23j
I need a wench if it is not taken, open to doing a deal!
Sat, Apr 9, 2016 5:33 PM
Inter674
Reply to d23j:
No good asking Wombat cause he never checks the box before mounting😄
Sun, Apr 10, 2016 4:51 AM
d23j
Reply to Inter674:
Wombat has spent most of his life mounting, one day he may get it right, na to late for that!
Sun, Apr 10, 2016 10:04 AM
Davross22
Send a private message to Davross22
Reply to d23j:
If this winch is availible Id be interested.
For old time sake!
Sun, Apr 10, 2016 7:13 PM
