D4 2t injector Copper sealing washer
dtcohen
Send a private message to dtcohen
Hi All,
Does anybody have a part number for the copper sealing washer that is used on the fuel return line on a d4 2t? The line I am referring to is hard line that goes to each of the four injectors. It is secured to the top of each injector with a banjo fitting and seals with two copper washers. I am missing a couple of the washers and would like to get replacements. I have seen many places that sell assortments of the sealing washers, but I am not sure what size I need or if there is anything special about the ones used on the injectors.
Daniel
Thu, Oct 1, 2015 9:32 AM
dtcohen
Just realized that I posted this in the wrong forum. It was intended for the discussion forum. my apologies.
Thu, Oct 1, 2015 9:37 AM
Mike Meyer
Thank you received: 6
Reply to dtcohen:
My D4 5T book says they are a "Gasket" 1F1569, I bought some recently so they are available.
Regards
Mike
Thu, Oct 1, 2015 11:18 AM
dtcohen
Reply to Mike Meyer:
Regards
Mike
Thanks Mike. I called up my local Cat dealer and they were able to confirm that 1F1569 was the right number. They ordered some for me. They were a little expensive at $0.70 a piece, but only needing a few I didn't figure it would break the bank.
Sat, Oct 3, 2015 1:06 AM
| Kingaroy, Queensland
