d333 cat engine
d333 cat engine
lloyd58
Send a private message to lloyd58
Hi Im looking for a top end gasket set for a D333 engine with serial number57H310 that is in a 1968 966b payloader or Traxcavator  as what is on the tag thankyou for any tips of where to find
Thu, Jul 15, 2021 4:43 AM
Thank you received: 45
My literature shows the 75A (US) to be equivalent to your 57H (Ca) and uses a 2S8271 valve grind gasket group (no water pump gaskets).
Plug the part number into ebay.
In 1968 Cat started introducing the D333c (4-3/4" bore) Is yours the 4-1/2" bore or 4-3/4" bore?
Fri, Jul 16, 2021 7:32 AM
lloyd58
Thankyou Old Magnet it turns out the whole engine is not worth fixing the head has 4 or 5 cracks in it one liner is loose on the bottom end to. So now im asking does someone know of a d333 or a 3306 running cat engine what I have found out so far the3306 will bolt up the same as the d333
Fri, Jul 16, 2021 11:03 AM
