D25U 8*** serial parting out
Showing 1 to 9 of 9 results
MR.22
Send a private message to MR.22
Parting out a running 5UD2. Undercarriage not good. Electric start pony runs very good. Big engine has one bad ingector. Side tank machine. Call with needs. Parting it out this weekend. 541-619-7394. Leroy. Can box up and drop off at fasenal for free
Fri, Feb 10, 2017 10:26 AM
caterpillar13
where is it located ? are the steering clutches good ?
Fri, Feb 10, 2017 11:07 AM
MR.22
Reply to caterpillar13:
Oregon. They work. I will check this weekend when it's apart
Fri, Feb 10, 2017 11:27 AM
case on a cat
Send a private message to case on a cat
Reply to MR.22:
Does the d2 appear to have the original fuel lines and shut off valve for the pony motor? I'd be interested in all those parts
Sat, Feb 11, 2017 12:44 AM
MR.22
Reply to case on a cat:
They are original. But they are going to be sold with the pony motor. Thanks leroy
Mon, Feb 13, 2017 11:04 AM
case on a cat
Reply to MR.22:
I understand, No biggie.
Wed, Feb 15, 2017 3:48 AM
TyS
Send a private message to TyS
I picked up A 4U today that only drives on one track and has no brakes. Where in Oregon? I'm in Vancouver.
Fri, Feb 17, 2017 11:13 AM
MR.22
Reply to TyS:
Lebanon Oregon. Pony is sold
Mon, Feb 20, 2017 2:18 AM
MR.22
Reply to MR.22:
Oil cooler lines. 50.00
Water pump with fan good shape 75.00
Lower water pipe 25.00
Exhaust manifold 35.00
Genarator with gear 75.00
Sat, Feb 25, 2017 11:50 AM
doubleclutch
Send a private message to doubleclutch
Reply to MR.22:
Hi Leroy
What part number is the exhaust manifold.
Do you still have a decent water temp gauge on the machine?
Dale
Sat, Feb 25, 2017 9:55 PM
| Kingaroy, Queensland
