D2 water pump to radiator water line/I need one
silverstreak
Send a private message to silverstreak
I have a D2 5U serial #13,170 and I need the water pipe that goes from the water pump to the bottom of the radiator. It is an orchard model, which should not matter. Please let me know if someone has one they can sell me.
Tue, Nov 10, 2015 9:52 AM
gemdozer
Thank you received: 25
I check this afternoon but should still have one water pipe
Wed, Nov 11, 2015 12:47 AM
gemdozer
Reply to gemdozer:
I have a new water pipe 5f2064 but the # is't on but this pipe have a drain plug 3/4 inch on side and pipe size
is 1.621 approximatif and have bolting flange each end with 3/8 screw and look like 21inchs long
Thu, Nov 12, 2015 3:20 AM
josh
Thank you received: 14
Reply to gemdozer:
5f2064 is the correct lower water pipe for all the D2 U models.
Thu, Nov 12, 2015 3:38 AM
silverstreak
Reply to josh:
gemdozer, sent you a private message.
Thu, Nov 12, 2015 9:42 AM
Mike Meyer
Thank you received: 6
Reply to silverstreak:
I may be in need of one of these pipes for my D2 5U here in Australia, the one on my tractor is just about rotted through, anyone have a decent one?
Mike
Mon, Jun 11, 2018 2:56 AM
gemdozer
Reply to Mike Meyer:
Mike
I check today if am still have some
Mon, Jun 11, 2018 4:56 PM
gemdozer
Reply to gemdozer:
I check today and have no more water line . Sorry
Tue, Jun 12, 2018 6:33 AM
Mike Meyer
Reply to gemdozer:
OK Hector, I appreciate you checking.
Mike
Tue, Jun 12, 2018 7:14 AM
