D2 water pump
D2 water pump
Johnsd2
Send a private message to Johnsd2
I have a D2 5U6260 my water pump is leaking and I need a new belt, does anyone know were I can find one. I have called around and can't find any info on it..
Sun, Jun 25, 2017 9:18 PM
Lance Jones
Hi Johnsd2 ,You sound like You need New Bellow Seal [4f4769 ] and maybe even a Shaft if it is badly Worn [8B2578 ] Both readily available . If Cat can't supply go to Machinery Trader.com and type the Numbers in . The Belt is 5F7676 and should be available from Cat no sweat . LJ
Sun, Jun 25, 2017 11:53 PM
Johnsd2
Thanks for the info will get them c omming. Mine drips just a little bit need to get it fixed.
Tue, Jun 27, 2017 8:29 AM
| Kingaroy, Queensland
