D2 track adjustment wrench
3J
Send a private message to 3J
Hi folks.
I am in need of a 2F5131 2 1/4" wench used for track adjustment.
Anyone have one they are willing to sell?
Thu, Feb 9, 2023 12:18 AM
side-seat
I've found that a regular combination wrench like Proto etc works better at least on one of my D2's with a toolbar.  Found this out one time when I threw a track crossing a small creek.
The original ones have too big of a head to get in there when you can only turn the adjuster nut a degree or so.
But I'm sure you just want to have the original tools for a D2.
Thu, Feb 9, 2023 8:50 PM
3J
Reply to side-seat:
Thanks for the suggestion.
Yes I have wanted the tool that Cat provided but my threads are pretty badly rusted and might need the extra meat that the original tool will give.
I will just keep soaking them and maybe try a more modern wrench if the other does not show up.
Thu, Feb 9, 2023 10:00 PM
3J
Found on on e-bay.
Fri, Feb 10, 2023 12:30 AM
Thank you received: 78
Reply to 3J:
Found on on e-bay.
3J, be aware that the D2 track adjusting nut is actually a split nut, so once the 1/2" clamp bolts are loosened, the non-slotted parts can open up, making the remaining non-slotted portion of the nut pretty easy to turn. You might need to heat it some, and also use a square or triangular file to clean up the threads some
Tue, Feb 14, 2023 7:31 AM
3J
Thank you,that helps.
Wed, Feb 15, 2023 5:42 AM
