D2 pto mounting studs wanted.
Kaeson1972
Send a private message to Kaeson1972
Looking for a set of mounting studs for a D2 5U pto. Caterpillar here says unavailable..part number in the book is L-187. Thank you.
Sat, Dec 21, 2024 9:01 AM
rax200
Hi Kaeson1972,
Cat parts store show 0l0797 as the replacement stud.
Regards
Sat, Dec 21, 2024 11:06 AM
GrantJ
Thank you received: 10
Reply to rax200:
Hi Kaeson1972,
Regards
I recently went thru this with a PTO on a 22. I suspect the D2 uses the same sort of studs. Figure out how much longer they need to be than the originals and go to O,Riellys auto parts. They carry (or can get) the studs that have the two different threads on the ends. The course end goes into the rear housing and the finer thread takes the nuts that hold the PTO. I dont recall the proper name for that type of stud, but they should be able to find them. Get an old parts man. That usually helps. Grant.
Sat, Dec 21, 2024 10:21 PM
naylorbros
Thank you received: 31
L979 is a  1/8" is longer than L187.
Sat, Dec 21, 2024 11:23 PM
GrantJ
Reply to naylorbros:
A correction on my part. It was Napa Auto where I got the studs. I go in and out of auto parts store too often, and forgot which store I had found them at. Grant.
Tue, Dec 24, 2024 9:52 AM
