D2 Hydrolics
D2 Hydrolics
samcude
Send a private message to samcude
My D2 has pump mounted on front with a Dakota fluid tank and controls mounted on right fender. I want a pump/tank unit mounted on front with shield and control lever mounted on right fender and the steel lines to run down both sides of the tractor to the fenders and then Hydrolics hoses to each cylinder. D2 serial number 4U4159.[attachment=19142]image.jpg[/attachment] tractor in foreground is what I want. Send pictures to [email protected] or call 254-289-4169, thanks Sammy
Thu, Aug 22, 2013 8:04 AM
flmore
Send a private message to flmore
I have what you are looking for. The parts are located in central Texas. I am in North Dakota right now. Will be in Texas around the end of November.
Thanks Floyd
Thu, Aug 22, 2013 8:40 AM
samcude
Reply to flmore:
Thanks Floyd
See you in November!
Fri, Aug 23, 2013 4:04 AM
flmore
Reply to samcude:
O.K. I will PM you when I have a positive date.
Thanks Floyd
Fri, Aug 23, 2013 9:06 AM
samcude
Reply to flmore:
Thanks Floyd
Are you back from The Dakotas?
Tue, Dec 10, 2013 3:05 AM
