D2 Belt Pully
D2 Belt Pully
Showing 1 to 6 of 6 results
equipdriver
Send a private message to equipdriver
I have a D2 belt pully that I got from an auction in Morgan Hill, CA. I believe it is for a D2 as the old timer, who sadly passed away, labeled it on the unit as "D2". He did a good job labeling a lot of the parts he kept. The main body part number is 582640. The pully part will most likely need to get fixed as it has a rot like hole in it. See picture. I am located in the Salinas, CA area. I'd like to get $200 for it. Let me know if you are interested and I can send you more pictures. Thanks, Karl
Mon, Aug 11, 2025 12:26 AM
D8Dude
Thank you received: 28
Is the part number perhaps 5B2640? The number you quoted isn't a viable Caterpillar part number.
Mon, Aug 11, 2025 9:02 AM
equipdriver
Turns out a piece of paint makes it look like an 8. Yes it is a B, thanks for the heads up.
Karl
Mon, Aug 11, 2025 8:55 PM
D8Dude
I believe that is the number for a D2 dedicated drive belt pulley. Someone more familiar with D2's than myself would be able to confirm.
Tue, Aug 12, 2025 8:31 AM
clayton
Thank you received: 25
Hi Karl I’m interested in the pulley could you send me some more pictures at [email protected] and my # is 757-814-1842. Thank you Clayton
Tue, Aug 12, 2025 11:58 AM
Thank you received: 62
Why oh why did manufactures have to confuse things. Generally speaking the number cast in the part is not the part number. Called a casting number, no idea why it is not the part number????? In many cases it is close to the parts number. But it can be helpful in saying 2 parts are the same.
So if someone looks in a parts book, don't let this number convince you it is wrong for your tractor.
Tue, Aug 12, 2025 3:16 PM
equipdriver
Belt pulley sold. Thank you all for your interest. Have a great weekend. Thanks, Karl
Sat, Aug 16, 2025 12:25 AM
