D2
TractorDanD2
Send a private message to TractorDanD2
searching for a D3400 engine service manual and any other service information specifications for this engine. It is in a 5J5376.
Also for 4B7618 and 4B7617 tools for the injector pump.
And for the press tool adapters to do the final drives and steering clutches. I have to search those tooling numbers.
Cheers Dan, [email protected]
Sun, Oct 18, 2020 9:32 PM
Thank you received: 92
Hi Dan,
you can get by with two 9/16" combination wrenches to do the lifter settings--I found the said tools at The Dealer that hardly showed signs of use as they were often too flimsy to work on previously over tightened lifter screws.
My Cat 9/16" 8H8508 combination wrenches did the job well in all the Forged Body FIP's I did.
Mon, Oct 19, 2020 6:06 AM
