D2 5U bottom rollers
Showing 1 to 9 of 9 results
Packrat
Send a private message to Packrat
I am cleaning house and have a small pallet of D2 5U bottom rollers and bearing mounts. They look to be in good shape and I will send a picture a picture if interested. Any reasonable offer, I just don't want to scrap them.
Thu, Sep 28, 2017 9:08 PM
Hey Neil---jump on this!
Thu, Sep 28, 2017 11:52 PM
Thank you received: 78
Reply to dpendzic:
I know right Dan!
Packrat, can you please measure the rollers for wear. You want to measure the outside diameter of the surface that the track rails run on, in a couple of different spots on each roller - they may not all be worn the same amount. You're pretty close to me so I could come pick them up if they're what I need.
Fri, Sep 29, 2017 7:28 PM
Packrat
I know right Dan!
Neil,
I am out of town until Monday. I will do that and hold them for you. There are 4 double flange rollers and 1 single flange. I am not an expert but they sure do not look worn at all to me. I don't know how to post a picture. Talk to you Monday afternoon.
Paul AKA packrat
Fri, Sep 29, 2017 7:56 PM
Reply to Packrat:
Neil,
Paul AKA packrat
It may be simpler to measure the circumference and then compute the average diameter--if the shafts,bearings and seals are good the easiest repair is building up the diameter with weld.
Fri, Sep 29, 2017 9:25 PM
Packrat
Reply to dpendzic:
Neil,
OK, I just got home and measured them with a simple caliper and tape measure. I'm sure my accuracy is within 1/16". The 4 double flange rollers are 6 7/8", 6 15/16", 6 7/8", and 6 7/8". They are relatively flat across the surface and don't look too worn to me. The single flange does look a little worn but measures 6 15/16" but not straight across the surface. The flanges on the single flange roller are 5/16" thick and 3/16" thick. There are 16 bearing housings with bushings but no seals. Neil, if you are close by and can pick them up you can have them for nothing.
Tue, Oct 3, 2017 2:51 AM
Reply to Packrat:
Neil,
Hey Neil---I'll go half on the cost if you don't need them all---just need a couple of double flange.
Tue, Oct 3, 2017 3:55 AM
Reply to dpendzic:
Sounds like a great deal Packrat!. Can I swing by this weekend to pick them up?
Tue, Oct 3, 2017 7:31 AM
Packrat
I will be gone again this weekend but I can leave them where you can get them. How can I get in touch with you?
Tue, Oct 3, 2017 8:21 AM
Reply to Packrat:
No hurry, I'd rather swing by when you're there. I can come around another weekend or possible this Friday afternoon. Best way to reach me is email techarch at live . com or six 1 seven six 2 oh four 5 oh 6
Tue, Oct 3, 2017 9:25 PM
