D2-5U / 212 radiator core
Smithy
Send a private message to Smithy
I am currently searching for a radiator core for a Cat 212 Grader. The engine package is basically the same as the D2-5U. This unit has the oil cooler along side so I'm after the narrower version, Pt. No. 5F2141.
Wed, Oct 15, 2025 12:30 AM
Blue0xEF
Send a private message to Blue0xEF
Thank you received: 8
If you're out of options you might try Radiator Supply House in Foster, OR. They are set up to sell to dealers but will sell to individuals. The wide range of specialty and out of production products they stock is impressive. They will work with you. I discovered that the oil cooler on my 1948 D4 was the same as a D2 (later D4 coolers and radiators were taller). RMA to get the right part was not an issue. Be prepared for some sticker shock.
www.radiatorsupplyhouse.com
Mon, Oct 20, 2025 1:19 PM
Thank you received: 74
That's a good find BlueOx - I see they have 5U and 7U coolers orderable https://radiatorsupplyhouse.com/products/caterpillar-d2-oil-cooler-oc-3h2169-850584
Mon, Oct 20, 2025 6:54 PM
Kurt Bangert
Thank you received: 43
I have a core that need repair from my 5U - happy to talk with you about it. However, I ordered a new radiator from RSH and frankly I am very pleased with it, well built and pretty fast turn around. I had to do some trimming on the front top and bottom plates, but no big deal. I would recommend that you get new gaskets from Olsen's gaskets, they fit perfectly, the ones that RSH sends are just strips and will not work.
Mon, Oct 27, 2025 3:46 PM
| Kingaroy, Queensland
