coil for bosch mag needed 4F2282
oldbeek
Looking for a coil for my magneto.  MJK4/2360C-410. Book says it is a 4F2282. I have found one on machinery trader which is used. Anyone have an OEM  coil? I am shopping Cat used over aftermarket that dies in 10 hours of use.
Sat, Oct 8, 2022 8:37 AM
bruce oz
Thank you received: 23
https://parts.cat.com/en/catcorp/4F-2282
Sat, Oct 8, 2022 1:23 PM
rax200
Reply to bruce oz:
Hi All,
Just looked on the Cat parts store and it is no longer available.
Sat, Oct 8, 2022 7:31 PM
oldbeek
Reply to rax200:
Hi All,
Thanks guys. I have a lead on one
Sun, Oct 9, 2022 4:03 AM
gemdozer
Thank you received: 25
Reply to oldbeek:
I should have 10 coils for these BOSCH magneto
Sun, Oct 9, 2022 6:30 PM
oldbeek
Reply to gemdozer:
it is for a MJK 4/2360 C-410. I have done business with you before and very pleased. I have found out the coil I have probably was made for Standard Magneto in Illinois. It failed after less than 30 minutes of use, but the machine has been sitting for 2 years.  Are your coils original American Bosch? Used or new? Price. I am not much interested in using another after market coil.
Mon, Oct 10, 2022 11:02 AM
gemdozer
Reply to oldbeek:
Yes my used coil are BOSCH
Mon, Oct 10, 2022 8:22 PM
Thank you received: 78
Reply to gemdozer:
The new coil I received from Standard Magneto for my buddy's Wico XH2853S (I think - D2 mag) was a slightly larger form factor than the genuine Wico coil. I kind of test fit it and it looked like it would go in, but that's something to be aware of with replacement parts. I ended up continuing with the existing coil which was undamaged from having the battery shorted through it. Edit: to be clear, not a complaint about the coil, just that it had slightly different dimensions
Mon, Oct 10, 2022 9:37 PM
oldbeek
The aftermarket coil I had was from Standard Magneto in Illinois. I called them this morning and even though it was 2 years since I bought it and don't have my receipt, they said ship it back and they are sending me a new one. Quality company. AND , Thank You Gemdozer, your offer was generous.
Tue, Oct 11, 2022 2:05 AM
