Caterpillar Twenty-Two Lower Radiator tank
biggurn
Send a private message to biggurn
does anyone have a lower tank for a Cat Twenty-Two and would be willing to ship to Idaho?
Thank you in advance!
Tue, May 19, 2020 7:19 AM
GrantJ
Thank you received: 10
biggurn there are 4 different lower radiator tanks listed for 22s, depending on an F model or a J model and depending on the serial number. If you post your serial number you are more likely to get the correct part. Maybe they are interchangable, but I dont know that . Grant.
Tue, May 19, 2020 8:05 AM
biggurn
Reply to GrantJ:
thank you for the information!
[img]https://i.postimg.cc/vTRy7z0s/20200518-193031.jpg[/img]
Tue, May 19, 2020 8:31 AM
GrantJ
Reply to biggurn:
OK, that would be the first of the 22s. 2F1 to 2F7445. That is a lot of tractors, so it should not be too hard to find. People with more knowledge than me may be able to say if the later ones are interchangable. Sometimes it just a few fittings different, but sometimes it is a major change. Good Luck with it. Grant.
Tue, May 19, 2020 8:53 AM
biggurn
Reply to GrantJ:
Thanks again!
Tue, May 19, 2020 9:04 AM
Peter C
Send a private message to Peter C
Reply to biggurn:
Thanks again!
I have a 1J lower tank and a 2F upper. The difference that I saw was the 2F type has a boss on the tank which sticks forward about 3/4" to which the grill guard mounts while the 1J type doesn't have the boss. The grill guard mounts right up against the tank on 1J type. Mixing the two will cause the grill guard to slant either forward or backward noticeably. Adding spacers can correct that.
Pete
Tue, May 19, 2020 10:20 AM
Steve A
Reply to Peter C:
Pete
I do have a good 22 lower tank I would sell, will get a pic tomorrow.
Wed, May 20, 2020 8:57 AM
biggurn
Reply to Steve A:
Thank you!
Wed, May 20, 2020 8:58 AM
Craigorr151
Send a private message to Craigorr151
Reply to Steve A:
Is this a 1J model tank? Still availible?
Sat, Aug 1, 2020 11:23 PM
