Caterpillar HT4 loader (new)
Bob Mocha
Send a private message to Bob Mocha
Caterpillar HT4 hydrulic track loader this machine has been rebuilt from top to bottom. There was nothing overlooked in this rebuild including new liner kits, rods bearings, main bearings, valves ground, went through diesel pump, rebuilt clutch. Start engine same thing new bearings, rings, valves ground, starter rebuilt, carb rebuilt, start clutch and pinion rebuilt. Hydrulic pump and vavle body gone through every hose was replaced and all four hydrulic cylinders repacked. The transmission was taken completely down with new bearings. The ring gear and pinion removed and replaced bearings as needed same with the final drives. New rails, sprockets,new seat and armrests sandblasted and painted. All this done and has been run less than ten hours. I have all the receipts and when added up we have $24,000 in parts. Come look at it and make an offer.
Search cat caterpillar loader cat dozer cat d4 7U
Tue, Jun 19, 2018 7:13 PM
Moparnut88
Send a private message to Moparnut88
That's a beautiful machine! I hope to restore mine to that level some day!
Tue, Jun 19, 2018 9:08 PM
JoeG
Send a private message to JoeG
Reply to Moparnut88:
Definitely a fine job and a lot of work went into tht. Might I inquire what the large tractor with the cable control is behind it in the one picture? I am curious about the CCU you have mounted to it.
Wed, Jun 20, 2018 3:54 PM
Reply to JoeG:
Thats a D6D behind the HT4
Wed, Jun 20, 2018 9:20 PM
Bob Mocha
He is right that is a D6D with a N0. 25 unit and a homemade driveshaft
Thu, Jul 12, 2018 6:31 PM
| Kingaroy, Queensland
