cat ten intake valves
22B
Send a private message to 22B
any one have any good cat ten intake valves for sale or know where to get some short of machining blanks..?
Gib
Thu, Mar 13, 2014 9:00 AM
Canuckd2
Send a private message to Canuckd2
Its been a while since I done mine, but I am sure that the valves in the vertical Starting engines are the same , 5B.5101 intake, 4B.7264 exhaust, Ken
Thu, Mar 13, 2014 10:16 AM
catrjw
Send a private message to catrjw
Reply to Canuckd2:
The valve are the same used for the pony motors on the D7 or D8. When I did mine I got some from Cat, but they only had either the intake or exhast. I don't remember. I found that the Allis Challmers WD30 were a match and got them thru a local head shop. Also had to use the keepers. Worked out fine. Hope tis helps. [email protected]
Thu, Mar 13, 2014 6:54 PM
Catmatt
Send a private message to Catmatt
Reply to catrjw:
Cat still makes the exhaust valves for a ten. Just need to know the current part number which is 4b7264
Thu, Mar 13, 2014 11:45 PM
yancy44 mag
Send a private message to yancy44 mag
Reply to Catmatt:
mine came from the stating eng from a cat 2U its been a long time they had to do a little work but i do not now what and i used the carb to it was the same the linkage was different and i had to use the linkage of the one i had and make new from pick i took from a carb on a tractor with all the right stuff
Thu, Mar 13, 2014 11:51 PM
22B
Reply to yancy44 mag:
the number 5b 5101 for the intake is no longer available for the ponymotor, they do have the 4b 7263 intake for the 2u pony and the 4b 7264 exhaust for the 2u pony. have got one intake coming to see if it will work with a change of the keepers.. thanks all for your help if anyone has any more ideas please let me know..
Gib
Fri, Mar 14, 2014 9:32 AM
