Cat Part# T-207
Cat Part# T-207
jdkoller
Send a private message to jdkoller
What do you guys normally use for those four rubber pads underneath the gas tank on a ten? Cat shows them as discontinued.
Jamie
[attachment=36168]New Bitmap Image.jpg[/attachment]
Tue, May 24, 2016 11:31 PM
Cysco
Jamie,
I found an example of the parts you are looking for......kerosene lamp wick approx. 1-1/8" wide will be the same. The original in the picture is all cotton.
Hope this helps.....Bill
Wed, May 25, 2016 4:13 AM
jdkoller
Hey Bill,
That's interesting. The pads I removed from this machine were rubber so I ASSUMED they should be rubber. There I go assuming again.
Jamie
Wed, May 25, 2016 4:42 AM
Cysco
Reply to jdkoller:
Hey Bill,
Jamie
Jamie,
I just happened upon those two items and now they are on the shelf for reference. I found the lantern wick on Ebay. Bought it by the foot.....pretty cheap.
My Ten also had rubber installed.
Have a good evening....Bill
Wed, May 25, 2016 7:02 AM
jdkoller
Bill,
Did you replace the rubber to stay original or does the wick work better than rubber?
Jamie
Wed, May 25, 2016 8:18 AM
Cysco
Reply to jdkoller:
Bill,
Jamie
I replaced the rubber with the cotton pad. My tank seem to fit better as well.
Bill
Wed, May 25, 2016 8:47 AM
| Kingaroy, Queensland
