CAT Guy needs help with International T 20
r4dan
Send a private message to r4dan
Long story, ... but I've ended up with a little 1937 International T 20 !
The little tractor is in pretty good mechanical condition, ... runs good with good compression, steers / stops good. U/C is worn but above average and track shoes are excellent.
HERE IS the PROBLEM: . .... I need parts!
The fuel tank has been replaced with an incorrect one, ... appears to be from the larger TD 35 (way too big) and the radiator assembly is from a Farmall ag tractor ... no hood or side covers.
Do any of you guys know of an individual or may be a tractor salvage yard that may be parting out a T 20?
I sure would appreciate any suggestions as to who I might contact in an effort to find a correct Radiator, Hood and Fuel tank.
Thanks a lot, ... R4Dan
Thu, Jul 20, 2017 12:58 PM
captainhowdy
Send a private message to captainhowdy
Sat, Jul 22, 2017 8:05 PM
Jeff M.
Reply to captainhowdy:
i would ask these guys http://www.redpowermagazine.com/forums/?&_fromLogout=1
I have almost every thing you need I left you a PM
Sun, Jul 23, 2017 2:19 AM
| Kingaroy, Queensland
