Cat D7-3T Brake Linings
Prospectorgav
Send a private message to Prospectorgav
Chasing four sets of brake band linings Part number 5H2307 or equivalent to suit Cat d7-3T dozer preferably in Australia or suitable company who will ship to Aust. Parts book states 5H2307 is lining kit with linings and rivets to suit one brake band. Require two kits for immediate repair and two as spares.
Fri, Feb 2, 2018 6:21 AM
Thank you received: 59
Check the sticky at the top of discussion page for suppliers of parts. Florin is one of the most popular.
But considering where you are genuine Cat may be as cheap as after market when shipping is included.
Fri, Feb 2, 2018 11:46 PM
Lance Jones
Reply to Ray54:
I see on M.T. that Don Clark Tractors Sydney have 1 Set [02-84172928 ] Tilly's Toowoomba should have them ,[07-46336000 ] also ,Personally I would Go Genuine usually longer Lasting than Non Genuine , It's not the easiest Job , and Cat should have them in stock . Where in Aust. are You Located ? LJ
Sat, Feb 3, 2018 12:28 AM
Mike Meyer
Thank you received: 6
Reply to Lance Jones:
I just looked at the Cat Dealer parts website here in Oz and 5H2307 is not a good number, my D7 3T 20000-Up Parts Book shows the brake kit as 7F7591 but even that doesn't show on the parts search which is odd, I would have assumed those linings would be in stock. Try and use genuine Cat parts if you can, I put a new non Cat lining on one side of my RD6 from a brake and clutch shop in Bendigo and while it brakes OK, it sqwarks something shocking every time and drives me nuts.
Sat, Feb 3, 2018 3:28 AM
657cat
Send a private message to 657cat
Reply to Mike Meyer:
5h2307 is disconnitued . changes to
1 6y1937
2 6y1936
3 6y1938
32 7b5052
14 7b5056
Sat, Feb 3, 2018 4:44 AM
josh
Thank you received: 13
For 3T1-10730, set for one tractor is 3F6633 or two of 5H2309, also fits 7M, 4R1-3633, 9U1-3531, etc.
For 3T10731- up, set for one tractor is 7F7591, or two of 5H2307, also fits 17A1-19442, 10A1-1616, 9U3532-Up, etc.
Sat, Feb 3, 2018 4:49 AM
Prospectorgav
Reply to josh:
I run two D7-3T dozers. One engine number is 3T21612, frame number unknown as the control winch (25) and ripper are covering it which requires the linings. The other is dozer is engine number 3T16017, frame number 3T17311. After checking both parts books, the linings are different, thanks Josh. The lining kit I require is 5H2307 for serial numbers 3T20000 to 3T23646. The parts book is a bit misunderstanding as it states 5H2307-Lining group_2 each consisting of complete set of linings & rivets for one brake. Is this part number one or two lining sets. I will go to Westrac Caterpillar and try to get genuine parts if possible.
Sat, Feb 3, 2018 6:16 AM
josh
Reply to Prospectorgav:
5H2307-Lining group is for one brake, you need two of that part number to do both brakes. From 657cat's post, you might have to buy the parts individually from Cat, if no longer available as a set.
Sat, Feb 3, 2018 9:08 AM
Prospectorgav
Reply to josh:
Thanks everyone for your help. Went to Westrac Caterpillar and ordered parts today. Part number 5H2307 was replaced by several different numbers as per 657cat's reply. Kit was for one brake. I live in Western Australia and rivets are ex Perth here and the linings ex Melbourne, Victoria. I have just purchased the dozer and got the engine running last week after cleaning out the fuel tank and fuel system and replacing with new fuel and priming it through. The pony engine was seized but my other older dozer had the 24 volt starter conversion. I removed the pony engine and fitted the starter conversion as a temporary until I get another adapter plate made as I have to move this dozer about 10 miles from another mining claim. After getting it going, I travelled about 100ft and discovered the left clutch and left brake not working. The left final drive sprocket is also loose on the hub. These three things could be related. It is going enough now to load it on a semi to get it to my mining claim where I can delve into it further.
Sat, Feb 3, 2018 10:39 AM
