Cat D6C Cab
Showing 1 to 6 of 6 results
Jeremy Williams
Send a private message to Jeremy Williams
I have no need for the cab. I do have a couple more window or door glasses and a couple of the seals that hold them I believe. If someone can use it that would be great. I can hold it over the winter until spring or summer if paid for. I am looking for $500. Thanks, Jeremy
Wed, Nov 16, 2016 9:37 PM
Jeremy Williams
And it is located near the infamous Sturgis, SD.
D2 Cody
Send a private message to D2 Cody
Reply to Jeremy Williams:
Hi Jeremy,
I would be possibly interested in your cab. I was wondering if everything was factory and if it had been welded on or anything. Also does it need the square tubing frame props or does the cab just bolt to the floor pan or etc. Thankyou
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U15751
Thu, Nov 17, 2016 9:10 AM
Jeremy Williams
Reply to D2 Cody:
Hi Jeremy,
D2 Cody, The last picture shows the oval holes and the bottom 2 have been cut out some. Other than that I didn't see anything obvious. I think most things are factory, it does have a switch or something in it, which I am not sure if that is original. I do not know on the mounting. I will look at it tomorrow, weather permitting. I an get some pictures of the mounting if that helps.
Jeremy
Fri, Nov 18, 2016 7:18 AM
d21smith
Send a private message to d21smith
Jeremy
Is that a twin city in background?
Sun, Nov 20, 2016 6:58 PM
Jeremy Williams
Reply to d21smith:
Good eyes. It is a KTA MM-TC.
D2Cody, I haven't got the pictures yet. I will be up there tomorrow and send them to you.
Jeremy
Mon, Nov 21, 2016 4:03 AM
Jeremy Williams
Jeremy
I got pictures today of the mounting. It appears to bolt to the fenders. The back has the angle bracket, the other one is missing, and the front has holes in the angle iron on the bottom. The cab looks rusty on the bottom, but is still sound. At one point someone cut a hole in the top for an air conditioner possibly. They welded a piece back in. If you need any more info please let me know.
Jeremy
[attachment=39047]IMG_3764.jpg[/attachment][attachment=39048]IMG_3765.jpg[/attachment][attachment=39049]IMG_3766.jpg[/attachment][attachment=39050]IMG_3767.jpg[/attachment]
Tue, Nov 22, 2016 7:27 AM
| Kingaroy, Queensland
