Cat D318 Generator
Cat D318 Generator
Showing 1 to 7 of 7 results
I have a Caterpillar D318 generator. A dealer told me it was one of the oldest he has ever seen ... possibly from the late 1940s. Is there any interest as a collectors piece?
Thu, Feb 26, 2026 10:43 PM
Thu, Feb 26, 2026 10:44 PM
Thu, Feb 26, 2026 10:45 PM
Jeff M.
Where is it located at
Sat, Feb 28, 2026 1:25 PM
Thank you received: 78
Might be more like '50s based on being a D318 plus direct electric start but the serial number would tell the full story. Could you post the serial number (the one on the Power Unit tag) - can't quite make it out in the picture.
Sat, Feb 28, 2026 2:32 PM
Thank you received: 62
The first D6's with the D318 was 1948. No idea if the D318 was put into all applications at the same time or not.
Sat, Feb 28, 2026 4:00 PM
Thank you received: 222
Calif DOT had "emergency" Gen Set with very similar look. I always thought of it as an early D6 engine, station was put into service in '62 or so, the gen set failed in a big snow storm 1982. As I recall, it did not have murphy switches for temp/oil pressure, details are long lost now. - cts
Sat, Feb 28, 2026 4:05 PM
seyser
Thank you received: 60
Location and price?
Mon, Mar 2, 2026 5:26 PM
