Cat D2 5U electric starter rebuild - parts needed.
Dave-o
Send a private message to Dave-o
Hi guys.
I'm having some trouble trying to track down a pinion drive for this unit. 99% sure its a Delco Remy.
The motor is solid, but as you can see, the gear is pretty much cactus.
Any help greatly apprenticed.
[attachment=42681]20170528_145514_zpsyijehdfp.jpg[/attachment]
Mon, Jun 5, 2017 8:20 AM
Thank you received: 39
Picture is to fuzzy to be useful other than indicating it is a Delco 40 MT starter. As a conversion it uses the same 11 tooth RH helical drive as other Cat conversions. It is not the same as an original factor D2 direct start unit.
http://www.ebay.com/itm/CONVERSION-STARTER-DRIVE-FOR-PONY-MOTOR-CATERPILLAR-ENGINES-11-T-/360930526875?hash=item540922c69b:m:mVUgy5ivbEUePhUBT-SFxWQ&vxp=mtr
Mon, Jun 5, 2017 8:45 AM
Dave-o
[quote="Old Magnet"]Picture is to fuzzy to be useful other than indicating it is a Delco 40 MT starter. As a conversion it uses the same 11 tooth RH helical drive as other Cat conversions. It is not the same as an original factor D2 direct start unit.
http://www.ebay.com/itm/CONVERSION-STARTER-DRIVE-FOR-PONY-MOTOR-CATERPILLAR-ENGINES-11-T-/360930526875?hash=item540922c69b:m:mVUgy5ivbEUePhUBT-SFxWQ&vxp=mtr[/quote]
Thanks mate. Wouldn't let upload a higher res pic.
Mon, Jun 5, 2017 9:42 AM
