Cat Bolts ,nuts and washers.
Showing 1 to 6 of 6 results
zugecbobby
Send a private message to zugecbobby
Hi all. I am looking to buy some Cat Hardware. Bolts,Washers and nuts. Preferably bolts that have Cat stamped on the head. Old or new is fine. big or small sizes as well. I'm not using them on any specific piece of equipment. just using them on some projects i'm working on. anyone on here have any for sale or know a website where I could purchase some. ??? Thanks all.
Wed, Jun 17, 2015 5:24 PM
Lance Jones
There are basically 3 types of Cat .Bolts , The early Bolts just have a "C" stamped on them, fitted the early Cats next lot have like a Circle around the face , and I think it is CRL stamped inside that circle ,on the R2/D2's etc and the Later ones have the 6 lines [indicating grade 8 ] and have Cat stamped on them , there are variations of them . I buy all Cat Bolts, Nuts and Washers in most cases much Cheaper than the Local Parts Shops , That may not apply in the States but sure does where I live . Another important thing with Cat Bolts You can Buy them in Rises of 1/8 th inch Many of the others now only supply 1/4 Rises or even !/2 '.also small size Cat bolts have a Deeper head on them. You could Try a Wrecker for a Drum of Used bolts , You would get a lot of useful Bolts From that source . personably I would rather Buy New what I need . If you get a one safe Source book from Cat ,Most times You can relate Part Nos to sizes Remember to make sure You Quote 6 digits when ordering Like a T603 is now a 0T0603. LJ
Wed, Jun 17, 2015 6:28 PM
dtallon
Send a private message to dtallon
Reply to Lance Jones:
Here is an older chart showing part numbers for the different size fasteners. Some of these are likely superseded, but hopefully the dealer could get you the newer part number that replaced them.
https://goo.gl/photos/Cv191eJRfE1k6Xg76
Dave
Wed, Jun 17, 2015 10:14 PM
mog5858
Reply to dtallon:
Dave
well i just bought 4000 lb of new and used from a cat dealer. got 16 gal pales just weighting on a trucker to drop them off on a back hall. i think they cleaned up the hole shop and just keaped on getting more pails till there where done. i will see what i end up with when they get hear. got them off a online auction
Thu, Jun 18, 2015 8:54 AM
zugecbobby
Reply to mog5858:
ok. thanks , keep me posted. I appreciate it. . where are you located?? I'm near Pittsburgh Pa.
Thu, Jun 18, 2015 10:21 AM
zugecbobby
Reply to dtallon:
Dave
[quote="dtallon"]Here is an older chart showing part numbers for the different size fasteners. Some of these are likely superseded, but hopefully the dealer could get you the newer part number that replaced them.
Dave[/quote]
Thanks for the help . I appreciate it.
Thu, Jun 18, 2015 10:22 AM
zugecbobby
Thanks for the reply.
| Kingaroy, Queensland
